kfraser
Thread starter- Joined
- Jun 6, 2005
- 310
Just bought a 1977 Searay SRV220. It's an OMC MD# 990240E. I've just about got all the bugs worked out,(I think) including replacing the lower unit which lost the forward magnet clutch after five whole minutes in the water. Here's the next question. When trying to raise the outdrive I can hear the motor "click" and it acts like it wants to go up. If you lift on the drive and have someone depress the switch it will raise. Lowers just fine. Pretty sure the motor is shot, just wanted to poll the experts. I pulled the worm gear and shaft and they look fine. Second question...Is there an easy way to get to the tilt motor without "Having to pull the entire engine!!" Makes me wonder who designed this stuff... Here's an idea, let's put a servicable part in a place that is not humanly possible to get to unless you pull the engine...Grrr<br /><br />
<br /><br />
