1950's Wagemaker Wolverine wooden boat restoration ...
zool
You may be able to just use some small strips of butyl tape to seal in the edges with or without the routed wood strips.
kcassells
https://forums.iboats.com/forum/boa...oden-boat-restoration?p=10766621#post10766621
Oh it's zool Good morning.
sphelps
That kinda resembles me sometimes in the morning ...
A chrome piece top and bottom would look good also ...
archbuilder
looks good sam. do you actually need the additional support? seems like laminated glass would span from the outside to the inside.
sphelps
Not sure what type glass I will go with .
I know a pm for local glass company we have done a lot of business with over the years .
He said to make the template and bring it over with the brackets and we will figure out what to use .
Im afraid real glass might be more subject to breaking than some other product . Idk
archbuilder
Fuggly came from the factory with laminated, which is typical for automotive windshields. But now that I am thinking about it, you have an exposed edge so that probably isn't a good choice. I would probably go with tempered for safety reasons and it is much stronger than non-tempered. We use it for glass shelves all the time and I am amazed at how strong it is. Plexiglass is always durable, I just hate how it scratches. Fuggly's side windows were Plexiglas but I changed to laminated glass when I replaced them for the scratch resistance.
sphelps
Just doing a little prep on the speeditwin .. What’s a good filler to take care of a few dings over aluminum..
The prop is gunna get shined up . I might can talk the Admiral into working on that . At least get it close then I could finish it up .
ZC or SE primer for the aluminum ....?
247B72DE-BAA9-4800-A925-41AD272BCA88.jpegC6736042-DD66-4618-B35D-25A1B1BC38DB.jpegA33DAB1C-4242-47CC-909F-69153F7D1B8A.jpeg05A5CCC3-42FB-4E0B-87D2-B9E1718C74D7.jpeg
all-metal body filler is made with aluminum dust
devcon metal repair epoxy is another one
then again some west system epoxy and filler would work
kcassells
I'd go like grumpy says. Brazing aluminum can turn into a nightmare. Very thin wall. If you take that brazing route make some practice burns.
oldrem
Have to agree - I tried the aluminum rods a few times and always got horrible warp with them.
sphelps
Me thinks if it ended up looking like my welding or soldering jobs I had better stay away from a torch :eek:
sphelps
Woody , the thought of a making a bottom and top rail out of oak or mahogany to hold the glass did cross my mind . But I have the chrome brackets so I’ll probably just use them . At first I think I’ll try and keep it simple .
