Hi guys. Follow up to my previous posts. Had bought a 1988 boat which was not used since 1995. Had bad engine noise. Fixed the issue by replacing the rod and bearing. Now motor sounds great but does not idle. Bad gas in tank.<br />Filled up 14 gallons of gas on top of the old gas and took it to water. Had to keep pumping gas to keep the motor running. Run really bad when put to gear in slow speads. It jerks off and its ugle to see it jerking with tilt nose up and splashing water on the back as it jerks fast enough. <br />Once in deep and trim down boat runs really good. Touched 50mph the this weekend. <br />Needs cleaning of fuel system? Where to start? No such experience from fast. Fuel filter need repalaced. User manual says something about a filter in carborator, does that need to be replaced? How to clean carborator itself without messing up the setting? Help wanted. thanks
