Best Shop manuel for a 454 mercruiser
halflife
Can not find one online directly from mercruiser.<br /><br />who do you guys use?<br /><br />Is Seloc good?<br /><br />Thanks
Purduebarry
Re: Best Shop manuel for a 454 mercruiser
What make, model, year...details?
halflife
Wow i am a rookie!!!!<br />454 mercruiser magnum, carberated.<br />Not sure of the year of the motor but the boat is a 1989 Baja 240 sport. The motor has under 80 hours so it was either a rebuilt or new at some point.
halflife
I am a decent car mechanic so I hope to do most of the repairs that does not require pulling the boat out of the water myself, so mostly motor or electrical stuff.
tommays
You need the merc serial # should be on the motor if its a merc <br /><br />There a lot of different things they change so your working blind with out the number<br /><br /><br />tommays
Haut Medoc
Merc. manaul #9 should do the trick, I don't know if it is available online, Don S will know the answer to that.....JK
Don S
You will need a SN for your engine. Manual 9 is for engines 85-88 while manual 15 is for 89-92. Book 16 (in Bondo's link) is for 92 to 97 engines.<br />And you only have about a 50/50 chance of having an 89 engine in an 89 boat.<br />Neither 9 nor 15 is online.
