Lost power
Ringhede
I have a Mercruiser 4.3L. (year 2002) The power is ok up to 4000 RPM but it will not go up to 4600-4800. The propp is the same as in other boats of same type and they goes up to 4600-4800 RPM<br /><br />Can it be timing or carb settings or something else?<br /><br />The top speed is nearly same with 2 persons in the boat as if we are 6 persons.<br /><br />Strange!<br /><br /><br />The engine has got regulary maintenance every year.<br /><br />/Roland
Re: Lost power
Welcome Aboard Roland,......<br /><br />When was the Last Time this boat saw 4800rpms,..??..
Ringhede
Re: Lost power
It a fantastic forum.<br /><br />My boat has never reached that speed and high RPM:s<br />but there are other boats of same brands and same model and same engine and they goes much faster with same prop and engine. <br /><br />So I think there is something with my engine.<br />The power is realy good even with top weight in the boat but it never will go up in top RPM:s with nearly empty boat.<br /><br />The throttle opens full and I reach topp RPM when the drive isn't in gear.<br /><br />Normally it could be the wrong size of prop but the boat has the same size as other boats of same type.<br /><br />The speed is maximum 32 knots and other boats reach 40-42 knots with same engine and prop.<br /><br />The boat reach 32 knots even with 8 people in the boat, strange<br /><br />(in Sweden we use knots for speed, I think isn't same in US)<br /><br />The engine runs good and have a good sound but it lose power over 3900-4000 RPM:s <br /><br />Best regarads, Roland
Re: Lost power
THAT,..... Doesn't Matter.......Every Hull is Different,... Period.....<br /><br />I'm Guessing that your Tach is Wrong,.... Check it againest a Known Shop Tach........
horsefly38425
Re: Lost power
I would not bring rpm's that high with no load on the engine lots of bad stuff may happen like / kaboom
Ringhede
Re: Lost power
kaboom, why?<br /><br />If I speed up my cars engine to maximum rpm who it is allowed to run, noting strange happens.<br /><br />What is the difference with a boat engine?<br /><br />I have speed up my boats engine to 4800 rpm only a few seconds to see if the trottle works and so there isn't any stop in the wire system.<br />No kaboom.<br /><br />Back to bussines,<br />The speed of the boat is measured by a GPS instrument and is nearly same as the ordinary speed instrument.<br />But the speed is to low for this type of boat. <br /><br />I plan to check the timing this weekend to see if it is ok.<br />I know that it shall be 10* BTDC <br />But on what rpm:s? 650?<br /><br />If that is ok I will look at the carburator but it can be tricky to adjust, some guidlines?<br /><br /><br />Best Regards Roland
Re: Lost power
Well Roland,..... It appears that you've Already got your Answers,.....<br /><br />But,....<br />What Other boats do is Totally Irrevelant to What Your boat Does.......What part of this statement Don't you Understand,.????<br /><br />There's Probably Nothing Wrong with Your Motor,.... Yet,... Although if you keep Free-Wheeling it to 4800rpms with No Load,... There Will Be.......<br />Same goes for your Car engine....<br /><br />And Besides,.... What an engine will Rev to Without a Load Just Doesn't Matter...... <br />Your 6 cylinder will Rev to 5000rpms if it was running on Only 4 cylinders,.. WithOut a Load......<br /><br />I Think you're Just Over Proped......... Drop Down 2",+ See..........
Ringhede
Re: Lost power
My boat is a Uttern S64 with a Mercruiser 4.3L with 190 hk.<br /><br />I don't compare this with outher boats of same size and different brands lika Baylinaer etc.<br />I compare this with outher Uttern S64 with same engine.<br /><br />The boats are produced by same productions tools and have same form and weight.<br />The differense is that normally this boat should do 39-41 knots. (depends of wind and how clean the bottom of the boat is)<br /><br />A god picture of the boat<br /> http://www.batnytt.com/bn_2002/bn12_02/samm1_bn12_02.html <br /><br />The size of the prop is sama as the original. If the prop would be to big I should miss power when the boat is full of people.<br /><br />The engine sounds good and it have a lot of power up to 3900-4000 rpm but then it ends.<br />Strange.<br /><br />Last weekend I changed the sprark plugs and now it is NGK BPR6EF. The old ones was 4 year old and the company who made the services had never changed them.<br /><br />I come back when I have checked the timing this weekend. <br />/Roland
searay3
Re: Lost power
This may be an obvious...but, do you trim the drive up after the boat planes off? (plowing the bow)?
Ringhede
Re: Lost power
Now I'm back.<br />This weekend I have checked the timing.<br />At 650 rpm it is litte to low 6-8* and should be 10* <br />If I increase the speed to 1000 rpm the timing is 10* and werry stable.<br /><br />Can this be the reason why I'm losing power in top speed? (It seams to be so little wrong)<br /><br />At the cower of carburator I read that it should be some special timing equipment. I have used a ordinary who can be used to cars etc.<br />Did I use a wrong type or?
180shabah
Re: Lost power
If you have Thinderbolt V ignition you have to put the system into base timing mode first. Otherwise you will be way off.
boathog
Re: Lost power
ground out pur/wht wire start eng then ck timing.
KRS
Banned
Re: Lost power
bottom fouling, heavy hull (water in wood/stringers/transom/floor), unbalanced prop, needs tune-up, bad gas, bad tach (like Bondo wrote), .... I'll think of more possible reasons later.
whywhyzed
Banned
Re: Lost power
Trade props with a faster Uttern.<br />Check compression on the engine. Look for vacuum leaks around the carb base or manifold in general.<br />Check and evaluate the spark plugs.<br />Set up the carb with a vacuum gauge.<br />Check for exhaust restrictions (flapper valve).
