tonka_shores
Thread starter- Joined
- Jan 21, 2006
- 22
I've checked past posts but still have a question. The boat: 1972 Ford 302 & 888 Merc sterndrive. A bit of history: I purchased the boat late last season. It went directly to a reputable mechanic to replace the impeller. When back on the water, it had a tendency to overheat at low RPM, but was OK at WOT. This season, it seemed to get worse every time out. Now, we can't make it across the bay without overheating. I've replaced the thermostat. I've pulled the hose from the lower unit with the motor running and I get lots of water flow. I've blown into the manifold hoses and there seems to be no restrictions there. My last option seems to be the water pump on the engine. But there's no squeal or leakage from the pump. Could this be the problem? Is there a troubleshooting procedure I could follow? I'll soon be bald from pulling my hair.
