volvo sx-m
lilmandavis
is there a service kit that has bearings and seals together? drive ser#4202025929 needs a propshaft as well. wobbles .006 and seal area chewed into.
Don S
Re: volvo sx-m
Nope, no kit that includes bearings. There is a seal kit, then just order the seperate bearings and the shaft.<br />Don't forget, you will need to check and adjust the gear pattern, backlash and rolling torque on the lower after replacing the shaft.<br />And don't even THINK about taking it apart until after reading the manual on doing the lower so you know what you are going to need.
lilmandavis
Re: volvo sx-m
thats my next question.. what service manual do i need for this model.. i dont know whatyear this unit is or the engine, although ive replaced that with a 4 bolt 5.7l gs vortec. engine serial was.. 4012043233 product-3869058 249 glastron gs. is plastigage good for lashing? for reference? thats how i set some gears. seems to work good. but im not sure if its good in marine stuff though?
Don S
Re: volvo sx-m
Your drive SN should be 4202025928 and it's a SX-M drive with a 1.51:1 gear ratio.<br /><br />Your original engine was a 5.7GS PEFS. Which is a carbed EF model.<br /><br />For your drive work, you need Volvo service manual #7743008.<br /><br />No, plastigage is not good for "Lashing" an SX drive. Check with your local Volvo dealer, they can get you the manual. They cost around 20 bucks as I recall. I really don't do prices, I just fix em.
lilmandavis
Re: volvo sx-m
yeah. i knew it was a 1.51 thanks for the book info. and yep its a two barrel. does ef stand for electric fuel pump? seems on how many few moving parts that are in these drives, thier a real bear!!
Don S
Re: volvo sx-m
Nope, just random letters. Held over from the OMC/Volvo joint venture.<br /><br />This service bulletin explains the numbers.<br /><br /> Volvo Engine ID
