I was in the process of replacing the points+condenser with a Pertronix electronic ignition,started it up and the engine started overheating after 15 min. Conditions are: was running at high idle speed on muffs (tach not working so don't know exactly what rpms but it was sounding like high idle; was in middle of adjusting carb (soninlaw had "adjusted" it prior weekend! while starting tuneup process); watched temp gauge, went up to 200 deg. & shut it down. After shutdown there was steam coming from the bellows connected to the manifold, engine block definitely hot to touch, heat exchanger was too hot also.<br /><br />I had already inspected impeller pump and found the impeller to be intact, not beat up, but could not move it by hand either way is that normal? Left it in and just installed new gaskets after lubeing it.<br /><br />I plan to test the antifreeze & perhaps replace it if needed and inspect the impeller again. I am thinking it could be the thermostat too, don't know the age on it.<br /><br />Any other ideas of cause and diagnostic steps?<br />Did I do any damage, and if so what should I look for?<br />Thanks for the help.<br /><br />Joe
