What are late '80's SeaRay's like?
skategoat
Considering a 1987 Searay Sorrento. I know that they had problems with using cheap wood in the stringers in the 90s. What about '87? Were they better built?
Laakefly
Re: What are late '80's SeaRay's like?
I have a 1991 SeaRay 200 overnighter, I dont like the sound of cheap wood in the 90's. I better double check my floor I guess.
handball
Hi,<br />I bought a 1987 30 ft. weekender last year and have owned many boats before. This weekender is built really well as far as I can tell and I have been all thru the boat.It has a 19 degree dead rise (deep vee) and takes on a chop with out pounding.<br />I would recomend this boat to anyone. My sea ray is a straight inboard, would be real carefull about buying an outdrive, have it checked out before you buy.<br /><br />Bill
skategoat
Sorry Laakefly but a search on the Web comes up with a lot of complaints about soft floors, bare plywood stringers, etc. However, everyone raves about the exterior glass work.<br /><br />HK
delta breeze
Hey SKateGoat,<br /> I've owned two Sea Ray's.1980'S .They were great boats and good rough water boats.I did put a floor in both.I did the work myself so the cost was cut.It all depends on how the boat is kept.Inside or out uncovered?A 20 year old boat out in the elements will need work.I would definately by another 70's or 80's Sea Ray again.<br /> <br /><br /> Float em if you got em!!<br /> Delta Breeze :cool:
rogerwa
I have an 87 SR Seville Open bow. This boat seems very heavy compared to other boats of the same size and has a great ride as a result. The only softness I have in the floor is the panel over the tank. I suspect it has been removed and replaced with inferior PW. It doesn't appear to be rotting but it just flexes a lot. I have been very pleased with the boat in all aspects.
kalan2000
Delta breeze,<br /><br />What model Sea Rays did you own? I have a 1980 Sea Ray SRV-192 that has not rot at all as of today. The only rot I had was in the panel over the fuel tank and I replaced that last night with epoxied marine grade plywood covered with carpet. It's a small boat with a larger boat ride due to it's weight and deep V. I love it.<br /><br />skategoat, you might have a marine surveyor look it over for peace of mind. It shouldn't cost more than a couple hundred to confirm the seaworthiness of your next boat. It could save you thousands in repairs.
skategoat
I will definitely have a surveyor look it over. I've already had a pending deal get killed because a surveyor found water intrusion in the transom. I am just doing some research in advance of seeing the boat and spending the money on a surveyor. The way it's going for me, I might end up spending more money on surveys than boats.
quantumleap
It's a shame that the SeaRay name is starting to get a bad rap for wood issues, because otherwise, they are a top notch boat. Unfortunately, many people buy a boat and don't want to have to care for it or do maintenance. If you want a boat that you can leave out in the weather, it better be all glass or aluminum and have plastic seats with no upolstery or carpet. If the wood boats are put away in the right manner after each use, then the wood will be fine even if there is exposed wood on the floor bottom and stringers. Don't let them sit wet! Open all the hatches and lockers and take out the plug so it can dry out.
Skategoat, I own a '88 SeaRay 19' Sorrento bowrider with a 205 HP 4.3LX Mercruiser. I find the boat to be solid and handle well in the ocean. It has good power. The gel coat (maroon) is chalked and does not shine up well, but this is inherent to all dark gelcoats to some extent.<br />I do have some complaints however, such that I think the boat is an aberation from "normal" SeaRay quality standards. Over the last four years I have made the following repairs: The original keel under the Ski well was a piece of 3/4'plywood mounted on its edge(no resin or glass) and stapled to the plywood floor of the well. Water got into this space somehow and rotted it out. I ripped out the floor of the well and used solid pressure treated lumber to repair, new floor in the well etc. Next the hull cracked (probably due to too much flex) on the second strake from the keel, under the front seat on the port side. I cut out the floor (that I had replaced two years earlier due to general rot) and dug out the foam, layed glass on the inside of the hull, and added a frame. The stringers were fine, althought I doubled them for good measure. I installed new foam and a new plywood floor. <br /><br />In general, the boat is heavily upolstered, and water is trapped under the vinyl causing the wood to rot. This affects the side panels, motor box and seats. Notwithstanding these repairs, which should not have been necessary, the boat has high sides and good weight making it seaworthy. You need to load it properly (not too many folks in the Bow) or it rides like a barge.
delta breeze
Kalan,<br /> I had the same boat you have,With a 188 mercruiser.Great boat excellant rough water boat.I also had a SRV 220 I think was the model?21' 6" closed bow.nice boat I put several hundred hours on both boats and would buy another one today.look at pics on Quadzillas post today he just purchased a older sea ray,looks great and has the 165 merc inline 6 excellant package for a sea ray.I would like to find one my self. Delta Breeze
