Re: conversion for high altitude??
Hold on, there WD - Mercruiser has a 2.4:1 drive ratio conversion for high-altitude 3.0 boaters (QX's quoted 2.2 ratio uses the gears for the conversion they recommend for V6/V8 Alphas), but it really isn't necessary unless you do ALL of your boating above 5,000 feet. QX - you'll benefit from rejetting your carb down one or two jet sizes; you have either 1.55 or 1.60mm jets (Quicksilver OEM, about $3 a set from your local Merc dealer), depending upon the carburetor number (it's stamped on the side of the carb), so you'll be looking for something in the 1.50 range. You'll the technical info in the MerCarb section of the Mercruiser Service Manual (
http://www.boatfix.com/merc/Servmanl/13/13B5R2.PDF). For now, make sure you lean out your mixture to prevent carbon build-up. <br /><br />Also, 19" props for use above 5,000 msl is a pipe dream if you want to maintain printed RPM ranges and prevent lugging. You will more likely need to drop to 17" or even 15", again, depending upon your usual operating altitude. I think you'll probably want the 15", since you're more interested in hole-shot; it'll still give you good top end, at least as good as you've stated that you want. I have props ranging from 23" (for use for good top-end at low-alt lakes and at places like Powell) all the way down to 13" (for up at Blue Mesa (~7,500 msl) and higher lakes like Big Creek (~9,000 msl)). Like my tagline says - "Gotta have attitude at this altitude!"<br /><br />Don't bother with the gear ratio conversion. It's expensive, as you've discovered, and will screw you up if you ever want to run down and enjoy a weekend with your friends at Meredith or Pueblo.<br /><br />P.S. - if you want to drop me your e'mail, I'll keep you posted re: the forced-induction project I'm working on for guys like us, with lower-displacement motors operating in high-altitude environments. It's goal is NOT to produce obscene amounts of horsepower (I'm working on a separate 3.0 project that will yield normally-aspirated output in the range of 150 to 185 hp), but to maintain at least sea-level manifold pressure at altitude - effectively, turbonormalizing using a belt-driven supercharger.<br /><br />It's all in the 'tude, dude.....
