OMC OUT DRIVE STOPS GOING UP OR DOWN
nazareth
Hello Everyone.<br />Im a new boat owner and i have a problem that i need help on. I have a 1993 28ft Chris Craft Crowne with two OMC Cobra 5.0 motors, my problem is my Port side outdrive stops going up or down,, there is some kind of reset button on the outdrive pump, when i push the reset button the outdrive will go up or down for about 30 seconds and then it stops and would have to push that button again..Thanks for your help
dodge1971340
Re: OMC OUT DRIVE STOPS GOING UP OR DOWN
hi!! if your control box is tripping it could be a number of things :confused: . i would start with getting a seloc repair manual if you want to do the work yourself, you can do several test to determan yor prob.but to me if its tripping it its prob a short somewere i would start with the moving wires like your sending unit on the outdrive but if your not elect inclined i would let a tech look at it your messing with some expesive parts :eek: , since omc went out of biz :( .Good luck and God bless ;) Dodge
