1974 Mercruiser 165.GM inline 6
CaptRon66
After pulling the exhaust manifold today. I found the brass core plug on the head popped out a little. It was the plug furthest aft. I drove it back in with a block of wood and hammer. Now I'm having second thougths on putting the manifold back on as it will block the plug. Do these plugs usually leak after reseating? Maybe it should just be replaced. A little more info on the engine. It was winterized in September. Block drained and then filled up with antifreeze through t-stat housing.It was running good at the time. No water in oil then or now. Manifold is being changed for maintenance. Engine was pulled from my brothers boat and placed in mine. It ran good for him last summer till the engine coupler melted down. Not sure how or why the plug was pushed out. What do you guys think here? Troubles?
rplky
Re: 1974 Mercruiser 165.GM inline 6
Not sure on the engine but on the head freeze plug, its always best to reinsert with a little loc-tite around edge. what we used at Jasper engines at least,... just a thought... good luck
CaptRon66
Ok,I'll replace it. Is it easier to remove by drilling a hole and prying or should it be punched in on one side? Red loc-tite?
lilmandavis
blue. want it to push out if it has to!! dont want other stuff to crack when the plug wont push out :mad:
Bt Doctur
was it ever seated flush or was there a year that winterizing was not done in time or properly?
CaptRon66
Either is possible BT. This could have happened long ago.
