Taking off Risers and Rubber Exhaust Hose
Haut Medoc
Re: Taking off Risers and Rubber Exhaust Hose
There are two small holes inside the back of the riser where the water dumps...<br />Check these for clogging from rust/scale....<br />ID is inside diameter, as in, check the rubber boots for crusty shiite & clean them as best you can of the crusties.....<br />Perfect seal is more or less aviation grade gasket seal :) <br />I think I spelled everything right..... :D <br />If you have a raw water cooled system, 160- 170 is higher than normal for that engine, not over-heating, but above normal....<br />I think you do a have a restiction issue of some sort.....<br />Pull the riser & have a look, the gasket might cost five bucks... ;) ..JK
MSmith3615
Thanks again, Im going to pull the riser and rubber exhaust hose and have a look. I'm going to post the pics of the riser and let you guys tell me if its fit for service. :D
MSmith3615
Can anyone tell me if these are the only things I need to unbolt. I know there are two more nuts on the back side. Is there anything I need to becareful of when removing. Any more advice would be great and thanks again for the help so far.
MSmith3615
Anyone have any advice?
Haut Medoc
Nope, that's it as far as bolts go....<br /> Do ot use a screwdriver or other similar device to pry the riser from the manifold where the mating sufaces meet! <br />Invest in a rubber mallet ;) ......JK
