Re: Can't go over 3200 RPM's
I'm assuming your talking about the ignition coil, and if so you don't want to have 12 volts there too long, (ONLY for starting) it typically runs around 9 volts, after the engine is running, or in the igntion on, engine off. You may just have a ballast resistor, or some other kind of voltage limiting device going bad, or a bad connection somewhere in the circuit going to the positive end of the coil. Double check the service manual it'll tell you want you need to have, but its usually not 12 volts for ANY engine.
