ok guys...this is the deal.. first let me say i am a mechanic. just not a boat mechanic. although i have worked on several.. so im not totally ignorant. my boat is a 1995 18ft starcraft. 4.3 4 barrel carb.....alpha one gen two.. i bought it last year towards the end of the season.. I test drove the boat ran good worked good other than a slight vibration . i was sure it was just a gimbal bearing so i was ok with that.. we ran it the rest of the season and all was good except the slight vibration that never got worse. winterized the boat and that was that. a month ago i pulled lower unit and put in new gimbal bearing with the alignment tool. let me say that the old bearing did not seem bad to me at all..Put it together hooked it to the hose and started it up.vibration seemed the same but when you would drop it into gear and let it idle , it has a random clunk sound in the back of the motor upper gear case . sound like its the u joints or gimbal or something in that area.so i pull it back apart. i then realize that i screwed up and didn't get the gimbal bearing seated all the way in the housing. so i got another new gimbal and reinstalled. made sure it was all the in and took grease. all good.. reinstalled and same issue.clunk clunk ... so took it back out gimbal is full of grease ..alignment looks good. so i took the spanner nut out removed the upper shaft and installed new u joints went ahead and put new bearing and race in reset bearing preload reinstalled. same issue clunk clunk. so i decided to take it to the lake and just se... maybe it was just some backlash or something due to no force on the prop... so i took to the water.. once in the water didnt notice the clunk. maybe because of the water exhaust engine noise ETC.. BUT the vibration is still here and with the out drive trimmed all the way down turned to the left it gets a little worse chatter and vibration and when you turn to the right it chatters and vibrates so bad it almost causes the water to ripple. boat runs fine turns 4800rpm planes out fine but has alot of vibration., so me being who i am i start looking into other things and tearing things apart looking for this issue. i start to assume maybe the engine coupler is going bad. maybe the center of the coupler has tried to slip and is slightly cocked causing the shaft to put some side load on the gimbal. so i convience myself to pull the engine. everything looks fine. i have even started the engine in the shop floor so i can watch the coupler and the flywheel. all looks true and strait as can be.. harmonic balancer hasn't slipped nor is the rubber coming out of it. i have ran compression and all the cyl. 145lb every cyl. ignition is good. runs great. just vibrates and the u joints are binding.. and clunk.. you can even see on the double u joint coupler were there are some markings that is evidence of them making contact. there are no loose bearings or missing teeth in the drive unit. no metal shaving in the oil. no excessive play in the prop, nothing i cant find a thing . what could make the joints bind up.. what could be clunking.. why the vibration... did something get damaged when i put it together with gimball not all the way in. or could it be the bushings in the gimball housing . there is some play in them but idk how much would be to much. i am stumped just afraid there is something that is going to fly apart..
