How many gallons of resin do y'all think I'll need to replace the stringers and frames in this boat? It's an 18ft 1989 Sunbird Eurosport II. The stringers look to be 12 inches tall. My question is how would y'all suggest to replace these stringers? I was considering just sketching it all out with measurements and taking them all out and building the new substructure as one piece then putting it in and glassing it up. The only thing stopping me from doing that is I'm concerned that the hull will warp or twist and hurt performance. If you look inside the hull at the bow tip there is the lift point they used at the factory. I was thinking I could just lift up on it there and that would help hold the shape true, but I'm reluctant to do it without a few opinions first. Should I just do one side first or do y'all think it would be ok to just cut them all out and rebuild it as a unit
? Any suggestions are appreciated. <br />Here is a link to the pictures. The ones dated 4-24-03 and 4-26-03 are the most revealing of the substructure. <br /><br />Boat Pics <br /><br />Thanks<br /><br />James
