DramaFreeBoater
Thread starter- Joined
- Apr 4, 2002
- 7
Hey everybody,<br /><br />Recently I inherited a small Fisher-Marine 16' aluminum bass boat from my father. Due to illness, it has not been in the water since (I<br />believe) 1991 or 1992.<br /><br />I would like to get the boat back into good shape, but I really don't know where to turn. Here's the stats I have for the boat:<br /><br />1978 or 1979 Fisher-Marine 16' Boat - Aluminum Hull<br />Cox Trailer<br />35 hp Electric Start Johnson Outboard Motor - don't know what year<br /><br />If you need more specific information about the setup, just let me know and I'll dig it up for you. Thanks.<br /><br />As far as I know, the engine has not seized up, and is in great working order (my father was a fanatic about that kind of thing), but<br />it does need overhauling.<br /><br />Here are the problems I KNOW need to be addressed:<br />--------------------------------------------------<br /><br />- Engine overhaul - please elaborate what I need to do, and resources<br /><br />- New gas tank & fuel line - I know that's an easy one<br /><br />- New bench seat - wood has dryrotted & seat has pulled off of original mounts - where can I get a seat built or buy a replacement?<br /><br />- New livewell cover - same issue with the wood<br /><br />- The boat hull & trailer structure are fine - no wear, dents, or damage<br /><br />Here are issues I don't know about:<br />-----------------------------------<br /><br />* Boat:<br /><br />- Full electrical replacement??? - all wire covers shows signs of drying and splitting - including to engine area, side & underneath<br />console (including throttle gearing), and forward electrical (for running lights & trolling motor), bilge & livewell pumps, etc - if so how involved would this be?<br /><br />- Full replacement of all rubber tubing (for the livewell, etc.) <br /><br />- Console-mounted throttle handles & gearing - could they be bad/good -<br />hard to do?<br /><br />- Replacement of carpeting or wood underneath - seems structurally sound & solid - but is there anything that could be hidden?<br /><br />* Trailer:<br /><br />- Have to check tires to see if they're dryrot or just flat<br /><br />- Pack bearings on trailer?<br /><br />- Trailer springs good or bad - I have no idea<br /><br />- Light surface rust on trailer axle - big issue or not<br /><br />-------------------------------------------------------<br /><br />The boat obviously has a lot of sentimental value, but considering all the potential work that has to be put into it to get it afloat again, would I just be better off selling this boat as-is to someone that knows what they're doing? If so how much is something like this worth (I know not much). I'm located in Baltimore, MD, so if you know of any local resources I can check out I'd appreciate it. Also any online resources would be great too so I can start reading up or looking up information.<br /><br />If anyone has any advice for me, I'd really REALLY appreciate it. If you would like some pics to help with figuring things out, I'd be more than happy to provide some - just gimme a day or two to get them together.<br /><br />Thank you very much. I hope to see you on the water someday haha <br /><br />Willis
