need advice on painting deck
bdreaper123
I painted my deck on my center console boat and i must have rolled it on too thick because four days after i painted it i took it out fishing and through out the day i managed to smear the paint in many different spots. I used a single part poly paint mixed with nonskid by Interlux (brightside i think it's called). What should I do to fix this disaster? What kind of paint can i use that may work better?
D
DJ
Guest
Re: need advice on painting deck
bd,<br /><br />The paint is a good paint.<br /><br />Did you stir it properly?<br /><br />Also, that stuff takes forever to dry-hard. Give it some more time.
bdreaper123
yeah i stirred it pretty good. I'm sure the humidity here in mobile AL probably didn't help too much either. I guess that i will just scrap the sweared areas off then wait for the rest to set completely and then start sanding. I guess i will just throw another lighter coat of the same stuff on afterwards.
D
DJ
Guest
bd,<br /><br />My last project, painted with Interlux Brightside, took a good week to cure. I live in Arizona, no humidity here!
