4x6 engine mount block
Jamepc
What should be used for the 4x6 engine mount block? Pressure treated or not? Will resin adhere to pressure treated wood? Or would it be better to use non PT with CPES and fully encapsulate it?<br />Thanks,<br />James
D
DJ
Guest
Re: 4x6 engine mount block
I, personally, wouldn't use pressure treated.<br /><br />I would use a known good hardwood. A plywood layup, with epoxy in between the layers, would be the strongest.
snapperbait
Kiln dried douglas fir, completely glassed in, preferably, with epoxy resin..
Hooty
Epoxy don' care if the wood is treated or not.<br /><br />c/6<br />Hooty
crab bait
PT wood if'n its good & dry.. but it's only yellow pine.. good doug fir as per SNAPPERBAIT is the way i'd go.. least wise for engine mountin'..<br /><br />or go crazy an sandwhich the doug fir between some ply..
