Applying new non-skid
Capt. Stabbin
I am almost finished prepping my 1972-17 Mako for painting and am wondering what the procedure is for applying new non-skid over original factory non-skid? Should I completely sand down the original finish, or just rough it? I will be using Interlux Brightside (with flattening agent, and non-skid compound) over Gluvit. Any suggestions?
ob15
Re: Applying new non-skid
You could always test painting over a small area & see how it comes out. I would probably sand it and then repaint.
gbf03
You might want to check classicmako.com if you already havent.
Capt. Stabbin
Yeah I've checked out ClassicMako.com, it's a very good site, but I haven't seen anything about repainting the floor, although some of the other older Mako owners must have because the old Gulden's Mustard color floors are gone! Thanks for the replies........ anyone else?
mutron77
Interlux has a new product called "Interdeck"<br />It is a one part with flattener and non skid aready added. It comes in quart sizes for about $25. I have heard good things about it and am thinking of giving it a try. At any rate here is what Interlux says in their data sheet about prep.<br />-----------------------------------<br />Preparation for Interdeck <br /><br />PREVIOUSLY PAINTED SURFACES:<br />In Good Condition:: Wash down with Yacht Line Super Cleaner, rinse with fresh water and allow to dry. Abrade with 280-320 grade (grit) paper.<br />In Poor Condition:: Remove all previous coatings and prime the substrate.<br />PRIMING: All preparation for bare substrates is covered on the appropriate primer datasheet.<br />BARE WOOD: Prime with Yacht Primer or UCP.<br />STEEL: Prime with Yacht Primer or Interprotect.<br />ALUMINIUM: Prime with Etch Primer followed by either Yacht Primer or Interprotect.<br />GRP: Wash down with Yacht Line Super Cleaner, rinse with fresh water and allow to dry. Abrade with 180-220 grade paper. No priming necessary. - If any filling is required use the appropriate product from the Interfill range.<br />--------------------------------<br />That is for Interdeck. Here is what they say about<br />prepping for Brightside.<br /><br />BARE FIBERGLASS: In Good Condition: Begin by scrubbing well using soap and water and a stiff brush. Rinse with fresh water and allow to dry. Wipe a small area with a clean rag that has been wetted with Fiberglass Solvent Wash 202. While the surface is still wet, wipe with a clean, dry rag. Continue this process until the entire surface has been cleaned. Sand with 220-320 grade (grit) paper. Remove sanding residue. In Poor Condition: Clean as above. Sand with 80 grade (grit) paper. Apply Brightside Primer.<br />BARE WOOD: Sand surface, wipe clean. Apply Brightside Primer. Sand surface, wipe clean.<br />BARE METAL: Sandblast or grind, remove sanding residue. Immediately apply Viny-Lux Primewash 353/354 thinned 25% with Viny-Lux Solvent 355. Allow to dry for 1-24 hours. Apply one coat of Epoxy Barrier-Kote 404/414.<br />CLEAR EPOXY: Clean as for Bare Fiberglass above. Sand with 80 grade (grit) paper. Remove sanding residue. Apply one coat of Epoxy Barrier-Kote 404/414.<br />PREVIOUSLY PAINTED SURFACES: The surface must be clean and dry. Sand with 220-320 grade (grit) paper. Remove sanding residue.<br /><br />Also this may help. Also from Interlux.<br />Question How do you paint Non-skid?<br /> <br />Answer Interlux now offers three solutions for refinishing a non- - skid deck: 1) Stir and Apply – New! Interdeck – a pre - mixed nonskid deck paint. Interdeck is a slip resistant, single component, ready to use finish that can be applied over Brightside primer or Epoxy Barrierkote primer 404/414. 2) Mix your own non- skid finishAny one of the Interthane Plus, Brightside Polyurethane, or Toplac can be transformed into a nonskid deck finish by the addition of Intergrip Polymeric non- - skid compound 2398. Intergrip is a manmade plastic sphere having regular shape, low tendency to collect dirt, and has excellent non-slip properties. Once Intergrip has been added to Interthane Plus, Brightside, or Toplac, general application directions are followed, except there is no need to sand between coats. Our two part polyurethane, Interthane Plus, provides the most durable and long lasting finish for decks.3) Hand Broad casting method - While the first coat Interthane Plus, Brightside, or Toplac is still wet, sprinkle the Intergrip as required to obtain the texture of your choice. It is best to put the Intergrip in a flour sifter or salt shaker to dispense the compound. Avoid heavy application which will not assist in providing a more slip resistant surface. After the paint has been allowed to dry overnight remove the excess Intergrip and apply the second coat of Interthane Plus or Brightside.
Capt. Stabbin
Ah! A wealth of information bestowed upon me............... thanks.
18rabbit
I don’t think I would even mess with the old stuff. I would be inclined to apply new non-skid right over it.<br /><br />There was a discussion about this on another thread. A couple of folks here used a product called Durabak and recommended it. I went to their website, requested samples and they arrive quickly. Looks like good stuff, lots of colors. One-part, really easy to apply, sticks to most surfaces. Basically, wash the area you want to be non-skid and paint it on. You can take a look here:<br /><br /> http://www.durabakbedliner.com/ <br /><br />If you think it might work for your needs, you can request paint chips of the colors you like.
