Re: Play2wins Transom Crack-other suggestions for him from the other "exper
Ryoken, <br />I am going to use 403 for lamming wood. What do you use when sheathing in transom from inside? When "wetting out" wood, do you use only the epoxy, or add something to it. When I glass in my stringer and other things, do I add a filler to fiberglass, or just use the unthickened epoxy? When I clamp transom together, I am going to use stainless steel screws throughout - do I also bolt through were engine mount, etc holes are. If I bolt through, when epoxy cures, wont they be permanently glued and unable to be removed? Everyhting is cut and ready to go, just waiting for the weather to accomodate me for a weekend day!!
