Re: fuel sender
Dead Eye <br /><br />Run a wire from the sender ground terminal to a bolt on the engine block. This will ground it for sure if you suspect it's a ground problem. You could run one temporaily and see what happens. Normally, it will read empty if there is no ground. Re-read Kesh's post again and make sure you have it all wired up right at the sender and gauge. If none of that works, you may have a defective sender or gauge and he explains how to test it in his post.
