Rick K
Thread starter- Joined
- Oct 6, 2003
- 235
I'm getting ready to put a floor in my 14' Starcraft Runabout. Has anyone any experience in using aluminum "c" channel for cross braces for the floor? I'd run these the width of the boat,about 52", into the chinerail, which is about an inch deep, and secure with rivits. Then I'd install the plywood lengthwise to complete the floor.<br /><br />Would a 1x2 channel support the weight of the floor? The channel is 1/8" thick. I can go bigger, if necessary, but the thickness remains at 1/8". Or, I could use rectangular tubing, say 2"x3"<br /><br />I can weld supports down to the ribs, no problem, but if the channel will support the weight, I wouldn't bother.<br /><br />I found a local supplier that has just about any size/shape of aluminum stock, so making something up isn't a problem.<br /><br />Seems to be a better alternative than fabricating wooden stringers/braces, etc.<br /><br />Thanks<br />Rick K
