how to seal avon inflatable
phatmanmike
what do i use to seal this thing, neighbor gave to me, has a few leaks, ive seen some kind of "liquid rubber " but cant think of the name... anybody know?
bidlimit
Re: how to seal avon inflatable
I think West Marine sells a repair kit....
18rabbit
Mike, Again – there are two ways to approach the repair of a leaking hypalon boat. The preferred method is with an external hypalon patch. Not unlike fixing a bicycle inner tube…only industrial sized. Patching can fix big rips, too. The other way is to poured liquid sealer into the tubes, inflate and flip the boat around to coat all over the insides of the tubes. This is ok for pinholes and seam leaks. May take more than one application and it’s expensive.<br /><br />If you are not sure of the extent of the leaking, inflate the tubes to about 2 psi and go around the boat with a spray bottle of dish soap and water. Look for hissing and bubbling…the kind of stuff small children typically do when you step on them.<br /><br />When you inflate the tubes, do NOT inflate just one tube all the way, then the next, etc. There is an internal baffle between the tubes and you don’t want to stress it. Inflate one tube just until it has its shape only. Then go to the next tube… After they all have their shape, work in reverse order and fill to about 1psi. Then reverse direction again, taking the tubes up to 2psi. Don’t know what boat you have but it is probably rated to 3psi. In any event, it is virtually impossible to pop a tube with those little foot pumps. I can almost guarantee you can pop a tube with any other mechanical pump.<br /><br />One more thing...almost everyone under-inflates their boat. With a couple psi, the tubes will be hard and unyielding to hand pressure.
boater4life
I know of an inflatable service center called Suncoast Marine near Detroit and they are going to run some inflatable repair deals on e-Bay for like a 1/3 off starting next week. The package also includes cleaning and return shipping. The key search words are inflatable repair. They repaired my inflatable a couple of weeks ago and did a great job. http://www.suncoastmarine.net/
ob15
A freind of mine got the patch kit mentioned above for a tear in his. Said it was easy & worked great.
18rabbit
Boater - Simple repairs don’t require shipping a boat to get them done. And going over the boat with soapy water will result in a clean boat, too. :) <br /><br />Mike - There are a couple tricks that will result in a patch being as good as the original hypalon. If after inspecting the boat you decide you want to patch it yourself, post here again. Also, hypalon doesn’t leak. The material must be compromised for air to get past its layered construction
18rabbit
Bidlimit - Avon boats are made of hypalon. They are high quality boats made in England.
bidlimit
Ok, I didn't know. I'm pretty interrested in this discusssion actually because I have never worked on an inflatable before. Now I know.
