Guys was in Hospital for a bit will update soon, Dr said do nothing strenuous for a week or two. Yeah right Im Scottish will be back at it asap
Stay Tuned
Once the power head was off it was time to investigate the low compression on pot 4
It looks like this piston has be roasted alive.
Any other ideas as to what would make a piston deteriorate like this one ???
The 1978 and 79 140 hp had the 1 3/8 carbs(and possibly the 1977, however since the 77 had the oddball exhaust tuner, it may have had the 1 5/16 carb). 1980 and newer 140 hp and all 115 hp 1973 and newer(prop and crank rated) had the 1 5/16 carbs.
The Deflectors look OK as the rest of the block is as well.
I think it has been a replacement block not to long ago.
Will check out the carbs to night.
I dont want to end up with the same problem
