A good epoxy putty...
SS MoneyPit
What is a good epoxy putty to use on the stringers. I am attaching stringers to the hull.. Thanks.
crab bait
Re: A good epoxy putty...
you couldn't afford to buy 'already made' store bought epoxy putty...<br /><br />you should/have to mix your own.. <br /><br />go to www.us composites.com..<br /><br />get laminate weight ( thin ) epoxy an fillers,, silica , micro-balloons, an milled fiberglass.. <br /><br />mix epoxy first..<br /><br />then mix in fillers.. 70 % ,, 20 %,, & 10 %,, respectively... <br /><br />mix in till a wet peanut butter consitiency..
