Pony
Thread starter- Joined
- Jun 27, 2004
- 4,355
I hope everyone understands this. I want to put a bilge pump in my boat, but am unsure as to were to have the water output go. Im not thrilled about drilling through my hull, so i've thought of 2 alternatives and im wondering if either of them will work, and if they do which is best. <br /><br />1. Im replacing the old metal tank with a plastic one, so i was thinking of going through the hull where the overflow for that tank was....most likely will need to enlage hole.<br /><br />2. I was thinking of coming up from the bottom of the splash well (towards the top so water is well above drain of spash well) and then allowing the water to drain through the drain at the bottom of the splash well.
