- Joined
- Jul 18, 2011
- 19,649
Not the kind that you would see on YouTube, but . . .
Yesterday was 'boat launch day' for my 33 ft. Formula. After dozens of hours of maintenance and prep work the boat was ready for its seasonal launch. The boat hauler was scheduled to arrive at 3:00 to haul the boat down to the boat ramp a few miles away and then the Admiral and I would take the boat over to our harbor and put it on its mooring.
At about 1:30, I gave the engines a warm-up run for about 10 minutes each 'on the muffs' just to be sure that the engines were good-to-go at the ramp.
The boat hauler arrived, we get to the ramp, stick the boat in. I go to start the engines . . . the port engine starts right up . . . the starboard engine . . . nothing . . . no clicks, no noise, Nada. :facepalm:
The boat hauler pulls the boat back up the ramp and we try to sort things out . . . shifter in neutral position, kill switches, solenoid maybe . . . ignition switch, etc. Still nothing. And this engine had started up no problem about an hour before
The major issue being that the power steering runs off of the starboard engine. So, no steering if that engine is not running. If it had been the other engine, then I could have limped the boat over to the harbor on one engine.
We finally decided to bring the boat back to my house and set it back on blocks, so I could do some electrical testing and figure things out.
Using my voltmeter to trace things out, it looks like the solenoid gave it up the hour before when I started the engines :facepalm: Sort of 'funny' how a component can be working one minute and not the next.
Anyway, I went to West Marine before they closed for the day and got a solenoid (Sierra Brand is all they carry). I also ordered 2 Mercruiser solenoids to have some spares. The engines and the trim pumps use the same solenoid, so one is bound to go like what happened at the ramp.
Of course on my engines, the solenoids are buried down at the bottom of the 'electronics' box, so changing it out is a multi-hour task.
In my 13 years of powerboating, this is the first time one of my boats failed to start at the ramp. We are tentatively scheduled to try launching again next Saturday morning . . . not sure how much a 're-launch' will cost :noidea:
