Evinrude Boater
Thread starter- Joined
- Jul 6, 2004
- 1,148
I'm replacing the stringers and braces in my 16' fiberglass runabout and I'm thinking of re-designing it since I'm not replacing the wood core. The photo shows the only original brace that was in one piece (2x4 material). There were probably 4 or 5 of these on top of a small plywood stringer down the center. There's only about 4" of depth at the center. I was thinking of having 3 continuous stringers running the length of the hull stiffeners (just glassing them in now) and braces between these spaced about 32" apart. I'm also planning to fill the voids with foam. This is a thin hull and is quite flexible as I walk on it. Any opinions on how this re-design will work? Should I pour a higher density floatation foam, say 4lb or 6lb? Will the hull still flex too much in the 32" between the braces? I'm open to all suggestions.<br />
