Want to move gas tank to front
planerboardman
I would like to move my gas tank to the front under the casting deck.The reason for this is to get some weight off the back of the boat.Its a 21 foot starcraft with a 115 honda with 4 batteries and a 40 gal bait tank and 30 gal fuel tank.Would moving the tank futher away from the motor affect the gas pick up and performance of the engine?Thanks
crab bait
Re: Want to move gas tank to front
totally an exactly NO..!!<br /><br />it can be 20 miles away an it wont affect nuthin'..as long as the line is purged of air.. it's the same is if'n it was side by side..<br /><br />tip:::<br /><br />i did mine pretty far away,, had to temporary duct seal an air nozzel from my air compressor in the fill port an give it a shot of compressed air .. to get the gas line a soild fill of gas .. <br /><br />if you ever run outta gas.. you gotta do it again..
Indymike
I am having a similar consideration and was thinking it would be easier to move the batteries.<br /><br />Mike
Winger Ed.
Originally posted by Indymike:<br /> I am having a similar consideration and was thinking it would be easier to move the batteries.<br /><br />Mike
If you move the engine's starting battery very far, make sure you use good thick cables. I've seen it done by soldering the correct size ends onto arc welding cables about the size of your finger. If the cables are too long and/or thin, you might not be able to move enough electricity back to spin the starter. <br /><br />Moving gas, electricity or even air down a line or hose will cause some pressure or voltage drop from resistance. The smaller diameter the line or cable, the more resistance and more pressure drop you'll have. Moving DC voltage over wires has a much higher voltage drop over the same distance than AC, but a big battery and large cables, you'll be fine going 20 feet or so.<br /><br /><br />I've had gas tanks several feet from the engine, and never had a problem using 3/8" copper tubing for as much of the run as possible. Its good & slick inside, and lets the fuel flow real well with little resistance. Plus, its less of a fire hazard and doesn't crack with age as soon as the rubber lines. <br /><br />If the fuel pump is healthy, it'll be fine. If the fuel pump is getting tired, it may not be able to suck gas downstream fast enough for high torque or high rpm situations.<br /><br />I relate it to a car, they have fuel tanks at opposite ends from the engine, and they did OK back in the days of carbs. & mechanical pumps before tank mounted pumps for fuel injection systems. Even with a outboard, the flow rate of the fuel pump is about the same as a V-8 with a 4 barrel carb,,,, and opperates at almost the same pressure.
