duncan_ellison
Thread starter- Joined
- Sep 28, 2004
- 34
Usual story, bought an old 15ft speedboat hull for $200 and I'm now up to $5,000 including s/h engine, new floor, instruments etc. etc. etc....... nothing new here then
<br /><br />I was getting very excited about getting nearer the water until I took the precaution of cutting away a small area of glass INSIDE the transom and found that one side of the transom is completely shot. Probably the hull had been lying on one side in the water for a while as the port side is reasonably sound.<br /><br />Having already mounted the motor and resprayed the hull, my 1st choice was to use a product like Sealcast, but I spoke to them and they don;t have any distribution in Europe (yet).<br /><br />So... I've ordered up some marine ply and epoxy and intend to demount the motor and cut away the outside skin 2" away from the edge and replace the entire transom, then glass the cut section back in.<br /><br />I'm pretty handy with glass and I can always respray this section of the hull, because it's painted, I don't have to worry too much about gelcoat matching. But a post from JasonJ a few down now has me worried. He says - don't do it under any circumstances.<br /><br />I have restricted access from the inside, but I'm worried that going that route will be like "trying to paint my lounge through the letter box" and I'll not acheive the structural integrity I want.<br /><br />Does anyone have any experience of literally cutting away the rear section of the hull and glassing it back in ? How was it for you ? What technique did you use to stitch the section back in (woven glass tape ? / Mat ? / or what ?) How did you manage getting an oversize piece of plywood into the hole ?<br /><br />Has anyone ever tried a substitute for Sealcast ? From what I can see it's simply thin polyester resin with a bulking agent to reduce the weight. <br /><br />I realise that this is well trod ground, but having got this far, I don't want to make a major mistake now and I'm hoping you good folks can help out.
