Re: Ah! Dissolving Rope. It's installed w/ pics
Boomyal you are obviously having way, way too much fun. Now that you have it glued in place, personally, I would not use the stuff to create routes for water to flow. I would use regular old, el cheap-o sch 80 pvc and foam around it. I would design it so that when the boat is sitting in calm water all channels have an unobstructed down-hill flow right to the bilge pump area.<br /><br />Pvc has the advantages of smooth edges inside (wont hold water to grow bacteria/stink and cause humidity), you dont have to dissolve it (ok
dissolving it would be fun!), and it keeps the water out of contact with the foam that surrounds it. What barrier will you have between your water channels and the foam?<br /><br />My boat had sch 80 pvc used to connect bilge drainage thru a mid compartment that needed to stay totally dry (where the alu fuel tank was foamed it). Several lines are placed against the hull and thru stringers that were glassed in. An extra piece of pvc was placed on each side of the compartment hull, higher up, not for water to pass thru; its there to pull grounding or other electrical wiring under the floor and thru the foam without having to deconstruct anything. None of the pvc was visible under the foam.<br /><br />If you think you might ever need to run electric from one end of your boat to the other, now is the time to place pvc (or the cheap, gray electrical conduit) thru there, before you foam.<br /><br />Maybe I missed something. Looking forward to those pics.
