Perspective
- Joined
- Nov 12, 2017
- 31
Motor: 1986 Johnson 6hp on a 12 Jon boat
Model: J6RCDE
My motor is running like it is rich, carb clogged, won't throttle up all the way, etc.
The history of the motor. I bought it a few years ago from a guy who had it in his garage for 20 years without use. It looked brand new, fired up and worked great so I purchased it. Has run really good for about 4 years.
Last year the power pack failed so I put a CDI power pack and spark plugs on and it was fixed. About two months ago my wife and I went for a drive and ran 3 gallons completely dry and the motor quit. No big deal we went for a nice little troll back to the boat launch. I got busy and finally put gas in it this past week and took it out. It fired up and I went for a drive to go fishing. It ran real slow and would die if I throttled down. A few times it would run uneven and start to speed up and then slow down. On the way back it got up to speed a few times after about 15 minutes and planed out but would be right back to running slow if I throttled down. It is almost like it is running cold.
At home I checked the plugs and they were black and oily. I pulled the carb off and took it a part and it was sparkly clean inside visually. I sprayed carb cleaner through all the ports and they flowed nicely. I did notice the little tube inside the float bowl broken so I thought maybe it wasn't picking up properly. After putting everything back together and replacing all the fuel lines I tried starting it in a bucket of water and it still runs the same and leaves a lot of oil in the water. I feel like it has too much oil but I have double checked my mix cup. I mixed 16 oz of xd30 with 5 gallons of non-ethanol gas. The only difference was that it was slightly lower octane than what I usually use.
Is it possible the thermostat is stuck open preventing it from heating up? Carb really isn't clean? Ideas.
I mixed the fuel 50:1 per everything I have read online even though the motor says 100:1.
Any advice would be greatly appreciated.
Model: J6RCDE
