vroom ZOOM
Thread starter- Joined
- Aug 15, 2017
- 474
Hello.
this mercruiser 2.5 I got a week ago turns out to have water in the oil. is this a serious issue, or just an oil change? I dont think this is a surprise since the previous owner had the fuel line wrecked, the air filter off and the motor under direct rain in this form. havent checked the plugs to see if there was water in the cylinders. I fixed the fuel line, attached the battery to try fire up the engine, but no luck. I know it runs if you put gas into the carb, but it turned out that I cant even get the fuel from the tank to the pump. upon taking apart the pump I found it absolutely dry, and I cannot get the fuel from the tank. should I replace the fuel line or is there a screen or floating pickup which is so stuffed up with crud that I even cant blow through? I will get the brutal air compressor if I cant clear it, to clear it! (not through the pump of course!. also, what oil should I use in the engine? the cap says 10w 30, the motor says sae40. what should I use?
