Adding a outboard bracket
What would one need to do to convert a boat from an i/o to an outboard with a bracket. Besides closing up the hole in the transom. What would need to be done structurally
swimmin' for shore
Re: Adding a outboard bracket
Hi formula. Can't tell you what to do, but if you'll go over to the outboard-non-repair postings, there are a ton of discussions on this. I've looked some of them up, and it seems to be a pretty involved process. If you haven't made a firm decision on making the change yet, there are a lot of discussions on one vs. the other, as well. Good luck.
uncwillie
i made up a bracket with some 1 1/2" steel angle iron that was notched and welded for the inside bends. Add some cross bracing with 1 x 1/4". Fit a piece of hardwood inside the D shaped frame sides and bolt it in. Coat the whole thing with cold zinc rustproofer or other paint. Cheap and worked like a charm, made the boat faster, quieter, and safer with the transom notch filled in....
bossee
Hi formulafisher,<br />What boat do You have?<br />What size outboard are You planning to use?
hayhauler
Jim Condon, I'd love to see a picture of that. I've asked the same question as formulafisher. I'm to too confident about my 470, and wanted some options about replacing it some day.
uncwillie
hayhauler; that was many years and many boats ago so no pics available but if you teach me how to draw a picture here, i'll make a stab at it <br />;-)
JasonJ
Hayhauler, the 470, if maintained, is not that bad of an engine. It uses a Ford 460 V8 head and pistons, so if a head/piston issue ever comes up, it is fairly easy to deal with. Parts are still available. If you have the 4 inch exchanger, heat becomes less of an issue, there is a conversion kit to the GM style alternator to replace that funky liquid cooled setup. Overall, for its weight, a 470 puts out good power. I would really think the conversion through, the 470 gets a bad rap when in fact a lot of the people passing that information around are less than optimaly informed.<br /><br />If you do feel you really need to convert, you are looking at replacing the entire transom. A lot of I/O boats have small or minimal transoms because the loads are not being placed on the transom. You would need a full width, thicker transom, you would need to tie the transom to the stringer/floor system with "knees", which are basically braces that help transfer load to the stringer system. Since you would replace the transom with new wood, the outdrive hole in the outer shell is easily filled by layering in new glass. Then it is a matter of fabbing a bracket, which can be done out of steel or aluminum. You will need an outboard of at least 150 horses to equal the 470. It is a daunting project that, in the end would be more expensive than just rebuilding the 470 if it ever failed unless someone happens to just give you the materials and outboard. Good luck either way..
