hull damage
knarrman
while trailering my boat axle gave way....after getting boat home a rainstorm had come along and water had collected in boat. to make a long story short, noticed that water was dripping from center of hull(approx. underneath gas tank)..after a look see, found that(probably during axle accident) boat must have bumped trailer and there is now a small fracture in boat...enough to drip through when water in boat hull....what should i do about this....1st boat repair...thanks
Triton II
Re: hull damage
Knarrman please give full details of the boat:<br />Manufacturer, model, year, hull material etc so the iboats experts can give you educated advice.
llfish
Re: hull damage
Can you get to the area from the top? Years ago took my fiberglass boat to a Corvette body shop and repaired the crack/leak.<br /><br />Good luck
Solittle
Re: hull damage
How about posting a picture or two? It may be as simple as filling the gauged area with a bit of Marine Tex or may be much more involved. I few pictures will help point the way.
