I managed to get myself into a big project and need some advice. I have a 14' '85 bayliner fishing boat. I bought it last year for a low price to go with a motor I already had. When I was pulling the carpets out I noticed rotten wood so I managed to start pulling up most of the floor. I found lots of wet foam and began pulling that also. The weird thing was foam placement. There was a good chunk of foam in the front of the boat, smack dab in the middle of the bilge, soaking wet and blocking the flow from front to back on the boat. I thought I might be crazy but double checked the bow opening of the bilge and found a direct drain route to the foam. Is there supposed to be foam here? Also the stringers are fiberglass and integrated into the hull, when I go to lay the floor in what's the best way to cement it to the stringers?
