Jeepen
Thread starter- Joined
- Sep 20, 2018
- 15
I have a 2004 Fourwinns Funship 26' Boat with a 5.7 GXI-D Multi Port injection engine with Volvo Penta DuoProp outdrive. I am ready to go nuts and Broke trying to fix this thing. Sooo Very frustrated!!!! If someone could help me or lead me in the right direction I would pay them, just need my boat back.
Little history-I have owned the boat since new and never had any major issue's with it. It has 341 hours on it. Last year the riser gasket went bad and I sucked some water into the cylinders. Not enough to hydro lock. But enough when I pulled it out of the water and stored it for a month, it had built up rust on the valve seats causing very low compression. I installed new vortec heads and since put about 40 hours on the engine.
Now to my common problems. We had the boat on the lake WOT for about an hour, boat was running great. We pulled up on a beach and the boat sat for about an hour. When we got ready to leave it started right up and we idled out a ways. When I started to accelerate about 1500 RPM it started to miss, loose power, popping and backfire. So I stopped shut it down looked it over could not see anything obvious. So I started it, revved it up to blow it out and was able to get planed out. But noticed a big decrease in power. We got to the boat ramp pulled up to the beach deflated all the toys cleaned up the boat and got ready to load it. Well now it barely started, would not rev up at all and had to pull it on trailer.
I am a diesel mechanic and pretty savvy around most engines. But the boat world is just that it is a boat world. So here is what I have done for trouble shooting.
Compression test first thing! All 8 cylinders were at 150 psi-Assuming no compression or valve issues!
Fuel pump test showed that the low psi pump only had 2psi and High psi had 50. I thought Great, this is it! So installed new pump, and Regulator. Performed psi testing after install and the low pump showed 10 psi and high 55psi. Now the boat starts good and sound great hooked to the hose. So head to the lake for water test. Boat starts fine, idles up great engage throttle to1200 RPMs and falls on its face knocking, popping and backfiring. Back to the shop.
Now things point towards ignition issue. So I replace the following! New Cap, rotor, plugs & wires. Starts fine runs and revs good on the garden hose. Lake test same thing Knock, pop over 1200 RPMs. So Now I spend 600.00 on Rinda Technologies TechMate Pro. Plug it in and it shows no issues, everything is normal??????? Uggg!
Now I take extra steps towards possible ignition issues. Replace Cam position sensor in distributor, new coil, new module, cleaned MAP sensor and inspected all wiring. Headed to the lake and same thing! The only thing I have not done is change the crank position sensor, but it starts so good I can’t imagine that being it.
Also on the fuel system, I added new suction hose from the tank, verified no issue’s with the breather, added an inline clear filter that shows there is no restrictions or debris.
Someone out there has had to have this problem, any insight would be very much appreciated. I am willing to pay someone to help me solve this issue missing my boat very much!
