swimmin' for shore
- Joined
- Oct 25, 2004
- 490
Alright. Here goes. I've got 2 boats to get in the water, and I'm just returning from sea to get to the first. It's a 1968 Mark Twain, 17' fiberglass boat. It has a 160 hp I/O mercruiser engine that runs like a top. As a matter of fact, I bought it for 300 dollars and that motor started up with just a touch of starter fluid. So I figured that it was worth the effort. The transom is solid. The controls and attachments...horn, windshield, etc...were all in place, and the only mechanical thing I've replaced thus far have been the lights and an ignition. <br /><br />So here's the issues I'm dealing with, and I've been studying for 4 or 5 months for most of these items. The paint is weatherchecked all the way through and into the fiberglass. I've begun the process of sanding that down, and as it goes all the way down to glass, I'll plan to repaint. No problem, for now.<br />The floor is out. It was already out. The stringers are good, and they're set fairly close together for good support. I started cleaning up the edges with a rotozip and diamond wheel last night. That will be done by tonight, and I'll start cutting wood for the new floor. I've already purchased 5 or 6 gallons of epoxy, and the cloth is waiting. <br />The only issue I've come across that I wasn't prepared for is that the fiberglass enclosed wood beneath the front end of the motor is rotted and caved in. So, this block has to somehow be replaced. Does anyone have experience with this? I know I need to get the height right, but will the old fiberglass shell(the part that didn't cave) be accurate enough to do this? Any help would be greatly appreciated. James
