Re: My trompe l'oeil motor - pix
Originally posted by tengals123:<br /> tinkerer, awesome job mate, just awesome. where did you get the decal???
Leg is good but cowl isn't. Every time I wanted to spray the cowl the wind came up and made it hard to get a proper coat on. Also I didn't prep it 100%, but I knew it at the time. Whatever happened it was going to look way better than before. It looks OK in normal viewing to the average person. <br /><br />This is the last time I use spray cans as there's no flow control on them and they cost too much. Also guaranteed that about 10 to 20% won't work properly or will spit gobs of paint and stuff up a great job, which happened to me several times on the cowl. Used 6 cans of VHT engine enamel on the motor because there's a bit of heat in the leg. Got four of them for $20 at Super Cheap because some idiot priced them at $4.99 when they're generally around $13 to $15 each. The other two cost me $30 at Repco, whose prices are ridiculous but they had the only two cans I could find to finish the job. If I'd bought them all at the right price it would have cost me around $80. You can get the right quantity of paint tinted for around a quarter to third of that.<br /><br />Decals can be made at most signwriters as they generally do vinyl signs. The one I have is a red stencil, i.e. EVINRUDE is cut out of the red vinyl, laid on white vinyl. I just gave him a print of the "before" photo above with dimensions and explained what I wanted. Cost me $44, inc GST. There's people on eBay and elsewhere on the internet who'll provide standard decals for about $10 to $20 so check them out first. I couldn't get mine off the shelf as it's too old for the mainstream signs and a touch too young to be a classic.<br /><br />I stuffed up applying the decals because there are air bubbles in a few spots that I can't get out. I think you need to start smoothing them out from the centre, but you need two people for this, one holding the decal and the other applying.<br /><br />Say Hi to me if you see the motor.<br /><br />Cheers
