Alluminum Cleaning
newf1
I have completely restored the inside of my 14ft Lund fishing boat. I am now ready to attempt to clean the outside alluminum hull below the painted area.<br /><br />Can anyone tell me what to use to rid of the alluminum oxidization and restore to a smooth surface. I tried to use some alluminum/chrom automotive polish but will take forever and doesn't work very well.<br /><br />Thanks
newf1
Re: Alluminum Cleaning
Nuvite appears to be expensive. I may but polish for a finisher.<br /><br />Could I just lightly sand aluminum with a sanding disk in a drill/palm sander and then finish it with polish
cajun555
I would not use a power sander on it. Now on my old boat polishing the top half, I used a wet sand #400, plenty of water, went in a back and forth motion, then used a heavy duty rubbing compound, then went over it with Mothers Alum. polish. Alot of work but well worth it if you want a boat that shines.
John Carpenter
Go to your local janitorial supply house and ask for a gallon of AlumaBrite. They may have it under a different trade name, but it is an acid used by trucking firms to clean aluminum truck bodies. It is pretty mean stuff...usually hydroflouric, & you MUST wear protective clothing...gloves, glasses, respirator, etc. But it will clean it up.<br /><br />Or, go to Wal Mart and buy some mag & aluminum wheel cleaner...should also be an acid type product but is probably less agressive.
djvan
Be careful with alumabrite type products, we once used them on our aluminum truck fuel tanks, some got under the mounting straps and ate holes in a few of our tanks. A thorough rinse is required.<br /><br />DougV>
18rabbit
Unless you have something seriously wrong with the surface of that aluminum, I’d be inclined to not touch it. Clean with a sponge and soap and water. That's it. Aluminum immediately bonds with an oxygen molecule in the air and creates a surface that will not further oxidize (corrode) unless placed in stagnant water. I would not compromise that naturally occurring protective layer on the aluminum.
newf1
Thanks for all the info.<br /><br />I ended up just buying some automotive polish, buffed the surface lightly with a scotch pad, and gave her a coat of polish. Good enough.<br /><br />The ice up here in Sioux Lookout, Ontario, is goin fast and this newfie's got to get her in the water to test out the 1985 20 HP evinrude motor I rebuilt last year (just incase there are any problems).<br /><br />Cheers fellers.
John Carpenter
18rabbit and djvan are both correct. Unless you just have to have it shiny, the best thing to do is just leave it alone.
