walleyehed
- Joined
- Jun 29, 2003
- 6,767
need some advice here...Rebuilt my supersport 18 about 4 yrs ago..when I installed all flooring, I resin'd both sides and ends..on the front deck I used 3/4" A/C and soaked with a 50/50 mix of thinned oil paint, then resined over the top of that, again, both sides..<br />When installing rivets, I used a 1/2" wood bit and counter-sunk all holes about 1/8" so rivet heads would not show. I filled these holes flush with carpet glue on installation of carpet.<br />Tonight when putting the cover on, I stepped clear through the front deck right in front of the consoles..apparently the water had nowhere to go with the boat tilted up as I always do after washing, to dry for a few days before installing the cover, which IS vented, but I try and make sure it's dry anyway.<br />Am I looking at a new floor job??? I was wondering about GIT-ROT, but some of the wood has flaked away under the carpet...<br />Advice???<br />Thanks.
