What will it cost me?
massimofinance
My 1984 Bayliner needs a new floor. I want to rip out the old floor this winter, replace and epoxy (properly) all stringers, floor, seats, side interior runners, basically all the wood, 90% is rotten. <br /><br />Is it worth it? Should I just look for a new Hull? What kind? How much will I spend?<br /><br />If I do the project, which I actually look forward to, (good winter project, have a garage) what would it cost me?<br /><br />I just over hauled the outboard, so I know that is fine.<br /><br />Thanks!<br /><br />MAX
b.gagnon
Re: What will it cost me?
It is allot of work and will probably cost more than the boat is worth. It just depends how much you love the boat. For a cost estimate you need to post the type of boat you have, there is a good chance that someone here has done it before.
JasonJ
The cost depends on the materials you use. If you go epoxy on marine grade wood, you are looking at a considerable increase over polyester over a/b ply. The question that should be asked is whether you need to go overkill or not. Really, it isn't what they used when they built the boat (polyester over regular wood), it is how they did it. You could rebuild with poly and non-marine, do it carefully and correctly, and have an end result that will last longer than you'll ever need it to. You could go epoxy over marine grade and have it last longer than you'll ever need it to. <br /><br />You will recieve many replies that will tell you that epoxy is the only way to do it, and those replies will not be correct. Epoxy is only one of several ways to do it. Just remember, any boat built conventionally uses poly throughout, and consists of the same secondary bonds (stringers glassed to hull, floor glassed to stringers, etc) that you would be doing. Does epoxy bond better than poly? Yes. Does poly bond well enough to give you a safe reliable rebuild? Yes. <br /><br />So there you have it, and now you can see why a cost estimate is difficult to give. I will say that for just the floor structure, you are looking at $300-$1000 depending on your choice in materials. Then you are looking at additional cost for carpet, seating, etc.<br /><br />So now, since you could be staring at a bank account destroying figure to rebuild the boat, you have to wonder if it is worth it. The cons are: You will never get the money back, it won't increase the resale value, and it will end up costing in the range of simply finding another hull. The pros are: You will know the hull is sound, you will be able to get years and years of worry free service from it, you will know how to rebuild boats, and you will be free of potentially buying another hull that needs work.<br /><br />Also, by doing a rebuild, you can change things that you may not have liked wbout the layout. It gives you choices that simply getting another hull does not. You can also take your time, do it as the money comes in. If you enjoy this sort of thing, a rebuild is worth it despite the cost. If you just want to get out on the water, then another hull is a better bet. Good luck, and check out Realguns rebuild, he hooked up a Bayliner real nice....
massimofinance
Thank you very much for the information. I really thought it would cost me more for the materials (poly, regular plywood)
p12
You may spend more than your boat is worth, but you'll spend less than an boat of equivalent condition. What i mean is there is a very good chance that the replacement boat will have at least some rot also with this type and age. <br /><br />So its likely you won't spend as much as you would for a boat of equal condition to yours when you are finished.
dolluper
If you do it yourself,it will cost you lots of time,lots of itching,possibly a marriage.Make a supply list and figger your cost with no labour<br />like :example: 5+ gallons of poly or expoxy<br />exterior ply [fir] 3 sheets<br />stringer and brace material<br />floatation foam<br />mat cloth 50" times length of floor sold in metre's[39"] ex 15'= approx 5 metre's<br />mat or cloth to cover stringers and braces<br />grinding wheels,sanding disc's<br />face masks,rollers for resin<br />acetone<br />wood preservative<br />and possibly 3m 5200 for screw holes<br />bags for shop vac<br />See a little thought needed plan your attack :D
swimmin' for shore
Lots of small additions to this. Screws-Stainless steel. Lots of tools, if you aren't in a well-setup shop. Don't underestimate. Do everything. Add another 300 bucks for miscellaneous. It adds up quick.
