stillcantfly
Thread starter- Joined
- Sep 13, 2019
- 37
Yea I can put another one in I’ve bought 3 of them now
There is suction coming from the throttle body where the PVC tube would plug in does this mean cracked intake manifold?
When I covered all three ports. Oil,PVC valve both on the valve cover and the one at the throttle body it dies.
Also when the pvc valve on the valve cover was blocked the rpm was at 1000-1100 and the suction noise was gone just idling high. IAC I can hear moving and adjusting to what I was doing.
Boat ran around 1000 rpm still when I plugged the nipple the pvc hose slips onto on the throttle body it dies
One last thing with the oil hole and the pvc hole plunged air sucking through the pvc hose nipple on TB the inlet hole inside throttle body has very little suction don’t know if this means anything.
there are three holes under the throttle body but the gasket covers the center but has a tiny hole in a circle shape it doesn't appear that it goes any where the other two you can see go into the TB below the plate. took the boat out tonight and nothing new.
Also ran a vacuum test was getting 14-15” of suction from the throttle body nipple that the pcv would have plunged into
