Tire pressure
WIMUSKY
Well, this sure is an interesting conversation... Did I mention I max the air pressure on my 12yr old tires...:D
sam am I
If a tires wires could get crimped or soldered, how much over inflation could the tires be over inflated if the tires wires were crimped? or soldered?
The Force power
Depends on the gauge wire that's being used mostly. I'd say;:rofl: anything under #6 gauge I would solder & crimp
AND borrow a hammer off Grub54891
GA_Boater
I tried #6 gauge and it didn't work. Fell back on my old reliable digital gauge and the air pressure was right on.
ahicks
Makes no difference. Results would be the same. (they wouldn't hold air)
The Force power
as long as you don't grease those buddies with synthetic grease:drum:
I'm surprised the mods have not shut this down :facepalm:
GA_Boater
Sometimes you need a little diversion during the slow season. The OP was wondering, not needing any definitive answer.
WIMUSKY
The Mods are just lazy..... Bearing buddies? I pump til a bunch of grease come out them, is that enough? I know I'm getting grease to the back bearing because the seal is weeping.... All over the inside rim too. Kinda nice, now they wont rust... Just sayin............
Must be half time.
JimS123
I used to repack and replace rear seals annually. Then, one year I tried bearing buddies and just maintained them per the instructions. Nine years later I joined this forum and read all about how bad they are. That Fall I pulled all the wheels to repack them, only to find that there was no water in the hubs, all bearings were fully greased and everything was fine. Made me mad that I went thru all that trouble. They haven't been redone ever since.
JimS123
the answer to that is an automatic greasing system
One of my plant production lines had over 500 bearings, all in a wet harsh chemical environment. We would lose 5 or 6 bearings a week. The downtime to replace them, or even grease them periodically was staggering.
The automatic greasing system I installed was the worst thing I ever did. Ended up replacing all of the mechanical heads with grease nipples. The time for a mechanic to put 2 squirts in each nipple once a day was much less than the time to maintain the automatic system.
The Force power
ok, you got me sold, I'm getting a set
