Re: transom saver
Dingbat has a point, the transom is made to withstand a beating. It probably will last many years without a transom saver, and the T/S might not extend it's useful life significantly.<br /><br />But although the transom will support the weight, it will flex with every bump, and weaken with every flex, and when trailering you have the trailer right there to absorb some of the shock, so why not use it. <br /><br />And, not only does the water absorb shock, as quantumleap so graphically illustrated, but at 40mph the motor is in the down position, and will exert vertical force, but not horizontal force like when it's tilted up for towing and the center of gravity is shifted out and away from the boat. Try to break a pencil by pushing the ends towards each other (not a sharpened pencil!). Now put your thumbs in the middle and push out against your fingers.<br /><br />That's just my perspective; wonder if the transom saver concept really has engineering data to back it up or if it's just one of those clever marketing ploys?
