Know of any Stitch and Glue boats?
crab bait
Re: Know of any Stitch and Glue boats?
do you builder's have floatation in the hull ..so the boat's float level if swamped/breached..??
BillP
Originally posted by Mark42:<br /> 1/4" ply is so thin that I would think it is easy to totally saturate it with a dilute epoxy or resin before laying up glass. Any breach of the glass layers would just expose a plastic saturated plywood product. <br /><br />Regular ply might have to be substituted for marine ply to get good penetration and saturation. Is this a case where crappy wood is better?<br /><br />Any thoughts on that idea?
The deepest you could saturate any ply is to the first glue line and around the edges of the sheet. I've cut up a lot of epoxy saturated pieces of wood to see how deep the resin goes. In reality, highly thinned epoxy will penetrate maybe 1/16" deep if you are lucky and the wood is desert dry. 1/32" is more realistic. It's very easy to test your own materials and see this.<br /><br />You have to be careful when buying wood for boats. I bought 25 sheets of the expensive WEST sheathing ply (directly from WEST @ approx $50 ea.)a few years ago to "WEST" a 30' sailboat hull. If memory is right it was 5mm thick imported ply and sheet size was 5'x5'. I had several sheets left over and hung them in the rafters of my TOTALLY enclosed and weatherproof outbuilding. A few years later the ply delaminated...what a mind blower this was to see. It was supposed to be high quality marine ply with waterproof glue...but it wasn't. That boat was sold and gone shortly after the covering so I don't know how it held up for the long term. I used AB exterior to sheath two other sailboats and know they were still perfect 10-15 yrs later.<br /><br />If you want core material that is superior to wood look around at the structural PVC types like Klegecell. These are tough as nails and if they gets wet nothing happens except the boat weighs more. Only problem is few folks can afford to build a whole boat with it. Get some samples, you WILL be impressed.
fishingdan
BillP, my experience has been the exact opposite of yours. I have a few left over 2'x 8' pieces of 9mm marine meranti in my garage now. They have been there 3 years and look as if I bought them yesterday. The 5/16" exterier AB that I bought at the same time is long gone. It started checking within 1 month and was warped to a point that I couldn't use it within 3 months. To save some money, I was going to use the exterior ply for the sole and some internal bulkheads, but chose not to do that. <br /><br />A good test for plywood is to put a small piece in boiling water. It should not delaminate if the propper glue is used. <br /><br />I agree with you that the structural foam panels are excellent. As with everything in boats, there are always tradeoffs. <br /><br />One other thing worth mentioning is perceived value. A wood cored boat will be less attractive if/when reselling a boat to the majority of the buyers. Well informed buyers typically are not concerned, but many are based on old experiences or word of mouth.
D
DJ
Guest
On a side note- what would you guys be willing to pay for the boat I posted pictures of? Sorry to steal the thread I am just curious, would like to build a bigger boat in the near future.<br /><br />
Johnshan1,<br /><br />That is a VERY difficult question. While your boat is beautiful and no doubt rugged, it is unique. Personally, I would purchase something like that in the $8-10K range. Maybe more, depending on the engine. Yet, I know what it is and is not. That is NOT a boat that the average Joe can appreciate.<br /><br />If anyone were to buy it, it would most likely be a discriminating boater that loves wood (has probably built something like it) or a commercial use individual-IMHO.
BillP
Originally posted by fishingdan:<br /> BillP, my experience has been the exact opposite of yours. I have a few left over 2'x 8' pieces of 9mm marine meranti in my garage now. They have been there 3 years and look as if I bought them yesterday. The 5/16" exterier AB that I bought at the same time is long gone. It started checking within 1 month and was warped to a point that I couldn't use it within 3 months. To save some money, I was going to use the exterior ply for the sole and some internal bulkheads, but chose not to do that. <br /><br />A good test for plywood is to put a small piece in boiling water. It should not delaminate if the propper glue is used. <br /><br />I agree with you that the structural foam panels are excellent. As with everything in boats, there are always tradeoffs. <br /><br />One other thing worth mentioning is perceived value. A wood cored boat will be less attractive if/when reselling a boat to the majority of the buyers. Well informed buyers typically are not concerned, but many are based on old experiences or word of mouth.
Back when I bought the imported ply from WEST I think they thought marine meant "sealed in epoxy will make it water proof". I have never had or seen marine or exterior ply delaminate while sitting in storage. Careful storage will keep most ply from warping though. I talked to a boat builder who built large (80') plywood boats and ordered sheets by the hundreds. He made a stacking grid to air dry imported marine pt ply without warping. I don't know how big a problem checking is but I think saturating with epoxy keeps it from happening. None of my epoxy coated ply boat stuff has ever checked and that has to be 100 sheets or more. I grew up with plywood boats and most were done with exterior...some just painted and others glassed with 10oz cloth and polyester. They had very few problems if you kept them off the ground and dry. <br /><br />Here's one of my "WEST" jobs. I'm preping at this point. If memory is right it took approx 25 sheets (4x8x1/4" AB ext) to do the bottom and 60 gals of epoxy. This boat was done in 1980. The guy I sold it to has sailed from Florida to Alaska without problems with the sheathing. <br /><br />
fishingdan
Originally posted by crab bait:<br /> what about the floation question..
Most designers of mid-size or larger boats will indicate where foam can be used and will help one to determine the minimum amount. Typically foam in poured under the sole and any unused compartments. I prefer 2-part closed cell foam that you mix and pour, but others use insulating foam panels, empty soda bottles or even those toy pool "noodles". <br /><br />The big decision is whether one wants simply positive floatation or level floatation. <br /><br />Positive floatation is the most common approach. With this approach, one will have enough foam in the boat to keep it floating in the event of a disaster. The hull will probably "turtle" on you (flip when water enters the cockpit and the center of gravity is changed - can happen very quickly), but it will float. <br /><br />Level floatation requires that you have enough foam located up near the sheer line to prevent the float from flipping if the cockpit is swamped. This may or may not be feasible depending on your boats design. Typically, you need a design with a nice size gunwale where you can hide foam underneath it.
fishingdan
My boat has basic positive flotation. The entire under-sole cavity is filled with foam. I ran PVC pipes under the sole before foaming for wiring.
KRS
Banned
Dad and I built the Glen-L design "Row-Me", it's a nice little row boat, we bought the plans for the deadrise 19, but never built it. Also stitch-n-glue built a 21' sea kayak, but I don't know the design.<br /><br />Very fun to do, never did a typical frame-up construction, so I can't compare.
