Hi<br />after putting in the new transom, I now must drill holes in the boat to accomodate the transom adapter on my jet drive.<br /><br />I have read to drill, fill the holes with epoxy , and then drill again? does that mean I have to drill oversize?<br />can I just coat the bolts in epoxy mixed with cabosil and run them through?<br />or can I just coat the inside of the holes with epoxy and then run the bolts through when it dries?<br />drilling oversize is problematic because I will have to enlarge the holes on the transom adaptor, which I don't want to do. <br />if it matters I have to drill 12 holes.<br /><br />thanks
