I have started restoring a high performance bass boat and already know that I have to remove the cap to get to the area that needs replacing. I am a bit fuzzy on this. After I remove the cap I know that I have to replace the stringers and transom. My question is grind all the glass of the stringers and remove. Grind off the glass at the transom and LEAVE the outer layer of the finished hull at the transom or do I have to cut the transom completly out. There is only a small area in the transom that has gotten mushy. I also know that I have to attach the stringers to the transom which I have researched thouroughly. I am using a product called highfax that is impervious to water and going to sandwich the highfax with marine ply to add superior strength. I am also using the vacum bagging process to aid in a superior finished project. So I guess my main question is can I save the outer layer of the transom if I carefully grind off the old before replacing the new. The reason for this is as I stated this is a high performance hull with a built in transom setback.
