Cayo Boater
Thread starter- Joined
- Sep 6, 2003
- 22
I've read through this forum this is a good method for removing oxidation on my boat. My boat is a dark blue. Won't this scratch??
Ayuh,.........<br /><br />That's what Color Sanding is All About,........ <br /><br />You just Keep Scratching it with Finer,+ Finer,+ Finer,+ Finer,+ Finer,+.............Scratches...........Won't this scratch??
I mean skip using the scrub pad and comet if it is not bad and go right to polisher and rubbing/polishing compounds.<br /><br />As far as the engine cover, paint does the trickOriginally posted by Conchy EL:<br /> Great, thanks for the help. I'll go ahead and try the polisher first as suggested. So MARK42, are you saying if it's not too bad to use a polisher with a rubbing compound, or the polisher with the comet? One other question: what do you do to bring the shine back to the cowling (sp?? - cover for the engine)? I'm new to boat restoration so need as much info as possible. Thanks!!
<br /><br />For the cowl I used pretty much strictly plastic-kote lacquers. The only exception is the red which was on one of the plastic cowl decals. I used a paint designed for plastic by krylon. I have had a lot of luck using those lacquers before. The primer was ust some all purpose enamel primer. Oh and of coarse the metal flake blue that plastic-kote makes is great and it looks fantastic. I had used one of the other colors before and with that good expirience I knew I wanted to use it for this project.<br /><br />For the actual motor I am using a Truck/ Sprort Utility paint that I found to almost match the factory blue. I figured it should be fairly durable since I wont be clear coating the leg. Tempo makes the factory color but the only places I found it, they were pretty expensive. For the above the waterline stuff I used metal primer.Originally posted by Mark42:<br />I mean skip using the scrub pad and comet if it is not bad and go right to polisher and rubbing/polishing compounds.<br /><br />As far as the engine cover, paint does the trickOriginally posted by Conchy EL:<br /> Great, thanks for the help. I'll go ahead and try the polisher first as suggested. So MARK42, are you saying if it's not too bad to use a polisher with a rubbing compound, or the polisher with the comet? One other question: what do you do to bring the shine back to the cowling (sp?? - cover for the engine)? I'm new to boat restoration so need as much info as possible. Thanks!!A few members have posted about painting their motors. Seach and ye shall find the posts.
Originally posted by studlymandingo:<br /> the comet and scotch-brite make tiny scratches as you rub
